http://www.srtforums.com/forums/showthread.php?t=169215Originally Posted by raven3054@aol.com
i keep thowing an overboost code p0234, a code p2074 maf/map throttle position corelation at load and a threw and air/fuel metering code code today... its an 05 with a forged wastegate and agp motor mounts...... anyone got any ideas
I also have an 05, boosting to 18psi. I am throwing P2074 as well. Are you running stage 0 like me?. If so..this is the issue.Originally Posted by raven3054@aol.com
I have an 05' with a Forge wga. I have no codes. But some kind of boost issues do exist. Maybe it is the wga.
Yea brotha..You can say that again. I hit boost cutoff yesterday because I held boost at 10psi for too long at half throttle. PCM did not like that. Blew Code p2074!Originally Posted by kwik-e-nuff
dude that exactly what i did. thank god i'm not the only one... the guy i bought the wastgate from had it on his car, connected exatly the same way and he never had a problem and his is an 05..so i dunno. gonna try to figure something out to night. and yea its stage 0
