Results 1 to 14 of 14
Thread: change your clutch
    Post Master Jr. N2MB's Avatar
    the shore
    change your clutch
    Raise hood.
    Disconnect battery negative cable.
    Remove turbocharger solenoid pack from air cleaner assembly (Turbocharger Solenoids and Mounting Bracket). Position out of way
    Disconnect AAT sensor and remove air cleaner assembly.
    Remove throttle body inlet hose (from intercooler).
    Disconnect IAC and TPS connectors. Disconnect accelerator cable from throttle body linkage.
    Remove throttle body adapter.
    Remove battery.
    Remove battery tray
    Disconnect shift cables from transaxle shift levers and bracket.
    Raise vehicle on hoist.
    If necessary, drain transmission fluid at transaxle drain plug.
    Remove both front wheel/tire assemblies.
    Disconnect and remove both ABS front wheel speed sensors.
    Remove halfshaft assemblies and intermediate shaft assembly
    Using Tool 6638A, disconnect clutch hydraulic circuit “quick-connect” fitting
    Disconnect back-up lamp switch connector
    Remove starter motor-to-transaxle case bolts
    Remove front lateral bending brace
    Disconnect turbocharger pipe and power steering lines from structural collar
    Remove structural collar
    Remove four (4) modular clutch-to-engine drive plate bolts
    While removing bolts, one tight-tolerance (slotted) hole will be encountered. When this bolt is removed, mark driveplate and modular clutch assembly at this location, and be sure to align marks upon reassembly.
    Install and secure transmission jack.
    Remove left mount through-bolt.
    Lower engine/transaxle assembly enough to gain access to left mount and bellhousing bolts.
    Remove left mount-to-transaxle bolts. Remove mount
    Install screw jack and wood block to support engine after transmission removal.
    Remove transmission bellhousing-to-block bolts and remove transmission and modular clutch assembly.
    If replacing transmission, transfer impact blocker, back-up lamp switch, vehicle speed sensor and gearshift cable bracket
    Post Master Jr. kgmdawg84's Avatar
    Dirty JerZ
    i knew this was coming soon, lol, jay is damn good at this... he did mine in my driveway in like alittle over an hour, haha
    Extreme Member Grifter's Avatar
    NJ
    Quote Originally Posted by kgmdawg84
    Only to find out your axle was broken...:D
    Major Member Co Pilot's Avatar
    Old Bridge, NJ
    This is good for brett, his clutch isn't blown, but he can use this to figure out how to drop and open the dam thing. Great write up!!!
    (Wanna find one for my car???)
    Poster BIGDIRTYSPEED's Avatar
    Oct 2005
    monmouth county,NEW JERSE
    sticky
    the shore
    Quote Originally Posted by Grifter
    lol that was kennys fault...he said hey wanna change my clutch and i said otay:D
    Dirty JerZ
    LOL yeah, that was all my fault, but hey, i got a new clutch anyways!
    the shore
    wow i just noticed...look at the pic of the battery tray.in all these years with dcx i have never seen once an illustration with a hand,foot etc in it
    Dirty JerZ
    well, do you think the battery tray is magic? it cant levitate on its own silly! hahaha
    NJ
    Haha, wasn't pointing fingers, juts picking on Kenny.
    That is one freaky looking finger too.
    Jr. Member Nolimits's Avatar
    Near the Lab of Dr. Weird
    Quote Originally Posted by N2MB
    What the hell is this tool? And can I use something else that will sorta work?
    Major Poster
    Jersey
    Pry bar
    Major Poster SupeRfasT-4's Avatar
    Trenton, NJ
    great write-up, i was looking for a how-to because im putting in my clutchmasters stae 3 w aluminum flywheel this weekend. Shouldnt be too hard because im doing it at a garage with every tool you cvan think of and hydraulic lifts and also some profeesional mechanic help :)
    Newbie
    Aug 2008
    California
    does anybody know if there is a more informative how to change your clutch done already?? would really help
  1. NEW clutch masters stage 4 clutch/flywheel
    By 95Talon in forum Swapmeet
    Last Post: 12-11-07, 09:04 PM
Members who have read this thread : 5
