Results 1 to 5 of 5
Thread: TPS Sensor Removal/Install
    Jr. Poster DSurick's Avatar
    Feb 2008
    Howell NJ
    I purchased some new sensors to fiix my hesitation/lean WOT/backfires...
    What is the easiest way to get off the lower torx screw? The arm to the radiator fan is in the way (if it was 1/4" in another direction it wouldnt be an issue....
    Mar 2009
    Philly
    Quote Originally Posted by DSurick View Post
    confused as to why you need to do this to remove a tps sensor.
    --Chris--
    Feb 2008
    Howell NJ
    what are you confused about?
    I am changing my TPS sensor and i cant get a torx bit in there because there is not enough room between the screw and the radiator fan.
    Jr. Poster
    Mar 2006
    x
    hmmm..
    wot backfire is usually associated with lean condition or spark plugs (wires & plugs new? -- gapped at .028-.030 ?) - what mods do you have
    hanging rpm's is OFTEN a tps issue and resolved with a rewire.
    Extreme Member MysterySkittle's Avatar
    Feb 2007
    mid-nj
    I think we are confusing TIP for TPS sensors...If you are talking about the TIP (the one in the fender) then you just need to wiggle, jiggle, and tickle it till it comes out. Its a bitch and always end up walking away or bending the metal bracket for ease. If you mean the TPS sensor, just give me call.
    I think i saved your number this time, lol
  1. removal of stock turbo
    By Petemac in forum Performance Modifications
    Last Post: 05-01-08, 09:48 AM
  2. TRUNK EMBLEM REMOVAL?
    By gesu69 in forum Visual Modifications
    Last Post: 11-18-06, 01:52 AM
  3. headlight lens removal
    By DannySRT405 in forum SRT4mation.com Site Discussion
    Last Post: 08-29-06, 01:03 AM
  4. Stock Sub removal ???
    By Too Tall in forum Audio and Electronics
    Last Post: 02-05-06, 11:09 PM
