check for any pulleys wobbling. None of them should be. Make sure yours bolts are torqued to spec. usual culprit is your idle pulley
changed the belts and the tensioner but my belt jumps off one groove on the ps pump pulley every time I drive. Any suggestions?
--Chris--
My Idle pulley? Where on my accessory belt is that?
you are either running the wrong size belt or not aligned correctly. but still inspect your pulleys to make sure everything is tightened down properly.
--Chris--
Belts the right size, double tapped that one. That's a question I had, I can't find how to actually align.
