bad gasket?
So I am back at this problem. I just replaced the Cam position sensor after a mechanic diagnosed the oil leak. After replacing it with a Duralast sensor it is still leaking. Anyone have a clue as to why this would be?
I guess it has to be the gasket, the Duralast must be a crappy one
check the cam magnet too... i heard things go wrong there too. i just replaced my sensor too, haven't thrown the code again at all... i don't think i have to replace the magnet.. if it happens again i will be getting both.
I am not throwing any codes so it leads me to believe that both the sensor and magnet are fine, it is just leaking oil
oooh ok.. my guess is the gasket .. not really much more it could be
That is what I figured. it is just weird because it is a couple days old from Autozone
This might be a ridiculous question but is there anyway that there may be an excessive amount of oil by the cam sensor which would make it leak ?
not that i know of. a oil flow modifier would lessen the amount of oil in the head though.
are you sure it's leaking from the sensor, and not from the valve cover?
I am positive. I have cleaned around and under the sensor, installed the new sensor and run my finger and a rag under it now and there is fresh oil.
maybe i can't picture how close the cam position sensor is in relation to where the valve cover meets the head. just making sure you weren't overlooking it somehow.
Yea I gotcha, trying to explore all options. I am going to get an OE sensor and hopefully that will do the trick. Sucks that I have already spent 40 bucks on the Autozone one but o well, you live and learn.
hey price on the cam sensor is 42bux with tax and everything just let me know i you want it might have to order it and it would be here tomorrow but i am working saturday could swing bye saturday if you want bec ill be here till 3
Hey I got back at you that would of saved me about 30 bucks damn. I actually already got the part from a dealer, I had to get it fixed. Thank You though, I hope it wasn't a pain
