Results 1 to 21 of 21
Thread: WTF: P0340-CAMSHAFT POSITION SENSOR CIRCUIT
    Extreme Poster sarty4's Avatar
    Long Island, NY
    ...drove to and from my ex's house today, car worked fine on the way there. coming home my CEL goes off and all of a sudden i can't go over 2500 RPM in ANY gear. car starts to bog. full tank of gas.
    help.
    Major Poster Frodo's Avatar
    replace the sensor
    Jr. Member MDRracing13's Avatar
    Oct 2006
    Old Bridge ,NJ & Williamsport, PA
    ^^ what this guy said.. seems like this is a common problem. i think it's $60 from the dealer
    Poster hercfe's Avatar
    Orange Cty NY
    its 42bux from autozone for a lifetime replacement warranty CPS. do yourself a favor and go to the dealer too and get a cam position reference magnet. they are 17 bux. do both at the same time for best results.
    Long Island, NY
    where is it?
    Long Island, NY
    thank you all.. keep the advice coming if anyone has something to add..
    thank you again
    Orange Cty NY
    Quote Originally Posted by sarty4 View Post
    where is it?
    The CPS is on the drivers side of the head on the front. it is the black thing shaped like a football. The magnet is screwed to the camshaft. you can see it clearly when you remove the CPS. It is prone to cracking. When i changed mine, the magnet had crazed badly, and was causing the p0344/p0340. The magnet only goes on the cam one way, it's really idiotproof. Just make sure you dont overtorque the magnet or the CPS, and make sure when you get the CPS, the new gasket is in the box.
    Long Island, NY
    Quote Originally Posted by hercfe View Post
    sounds good, thanks
    Orange Cty NY
    :bigthumb:
    Extreme Member Grifter's Avatar
    NJ
    Your ex probably fucked up your car while you weren't looking. Bitch!
    Orange Cty NY
    Quote Originally Posted by Grifter View Post
    haha, were you talking to me or sarty? my psycho ex wife back her fukkin honda into my drivers doors. i still havent been able to fix that shite.
    Post Master Jr. N2MB's Avatar
    the shore
    sometimes that code gets set because there is either too much crap on the magnet or a wiring issue as well. before you buy anything try cleaning off the magnet. pull the sensor off and wipe it off with a rag and do the same on the magnet that is bolted to the end of the camshaft. if enough metal particles stick to the magnet it can throw off the cam phasing. also take a good look at the connector and make sure there isnt any corrosion on the wires or signs of it being frayed
    Long Island, NY
    Quote Originally Posted by N2MB View Post
    both highly plausible.. gonna start with jay's advice first though haha
    Long Island, NY
    i can't find the damn sensor. in the garage now, any more details?
    NJ
    I don't have any pictures of the engine but isn't this the sensor that rubs on the intake? Driverside, going into the head?
    Extreme Member MysterySkittle's Avatar
    Feb 2007
    mid-nj
    Coolant may have dripped all over it aswell...check the coolant line directly above it that leads to the turbo. joe boostn had this problemo
    Feb 2007
    mid-nj
    yeah^^
    Long Island, NY
    Is that the cam sensor pictured?
  19. #19
    that's where it would be. that's just the magnet under the sensor.
  20. #20
    Long Island, NY
    Ok well I removed that and cleaned it up..
    Problem.. I might have stripped the thread going into the head, one of the bolts won't go back in. What do I do?
  21. #21
    Sr. Member Bungles's Avatar
    Won't go back in completely or just part way. If completely, see if you can throw some small washers in as well.
  1. P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
    By Jbeaud3297 in forum Problems and Maintenance
    Last Post: 04-21-08, 10:21 PM
  2. Throwing P1190-tip Sensor Circuit High
    By Boostn in forum Problems and Maintenance
    Last Post: 05-19-07, 12:07 PM
  3. Circuit City Car Show
    By mstrpball00 in forum Meets, Functions, Get-togethers
    Last Post: 06-12-06, 10:53 AM
Members who have read this thread : 2
