Horrible vid, but the car is coming together nicely man. CONGRATS!
My car also made 530 hp and491 tq on race gas at 27psi, Anymore then 27 psi and it was breaking up.
ok thanks. The coppers ran better then the iridiums.
I gpped the irids down to 26 and it still sucked.
Nice numbers dyno queen.
Juuuuuuuuuuuust kidding. :fryparanoid:...or am I.
great numbers! that turbo the powerband just keeps climbing!
Mike what are you spinning the motor up too? 8k?
Only 7k for now. The turbo peaks at 6200rpm at 27psi.
The nitrous run i sprayed at 4,000 rpms and had to let out at 4800 because it was braking up. If i get the breaking up issue fiqured out i may raise the rev to 7500.
Just gapped the plugs at .20 added a new coilpack and wires. I took it out at 33psi and no break up. I did not spray because it was hairy on the road already. I guess I will find out if i still get spark blowout with the spray at the track. Thanks for the info guys. Thanks dan for the coil pack.
:yay:
