Results 1 to 14 of 14
Thread: windshield wiper,problem...RESOLVED
    First off it snowed and it had coverred my wipers and obviously it didn't move.....and when the snow melted the wipers and fluid washer still did not work...how can I fix this??
    THE RESOLUTION WAS A BLOWN FUSE.
    4m Milestone Whore Award 20k oo3menace's Avatar
    New Jerz
    You tried to use the wipers with heavy snow on them? Why didn't you just use a snow brush to get the snow off first? You might have messed the wiper motor or something...or check the fuse? Good luck.
    Quote Originally Posted by oo3menace View Post
    How do I know if the wiper motor is broken or the fuse? Were is it located the fuse and the motor?thanx
    New Jerz
    The fuses are on the drivers side of the dash board, you can see the panel with the door open. The fuse will be blown if the metal connector inside is broken.
    And as for the wiper motor, I'm not sure. It could also be the switch itself on the steering column now that I think about it.
    Thanks a lot. Ill check the fuse later and see what happens. Also how can I check the switch itself??thank you .
    New Jerz
    I think you'd be able to use a multimeter to check it, if in the "on" position you should receive a reading (not sure of the spec), if it doesn't register I'd assume it's shot. I'm no expert though...maybe Jay or someone more knowledgeable can chime in.
    blown fuse, stripped gear in the wiper transmission (yes, it's called a transmission), burned out motor.
    as for the washer nossils, they're probably frozen over and internally. hair dryer. don't run the washer pump for long like that as you're likely to damage it too.
    Quote Originally Posted by Sota View Post
    Were is the motor located?
    Extreme Poster sarty4's Avatar
    Long Island, NY
    under the hood, silly
    Extreme Member Grifter's Avatar
    NJ
    Stripped the wiper or smoked the motor. I do about 100 of these every winter.
    The splines on the actual motor rarely strip out, it's the ones on the wiper blades that do.
    Quote Originally Posted by sarty4 View Post
    actually, it's under the cowling.
    thanks
    it was the fuse ...got it fixed ..thanks guys for you help:)
    glad it was something easy to fix. next time you might not be so lucky. never activate your wipers if your windshield has ice on it.
    New Jerz
    Quote Originally Posted by Default 8 View Post
    *tips hat* your welcome.
    Quoted for truth.
  1. Tiny crack in windshield, can enything be done?
    By SRT4Trb0 in forum Problems and Maintenance
    Last Post: 12-15-08, 06:02 PM
  2. Need new windshield..
    By Easy in forum New Jersey
    Last Post: 06-19-07, 11:55 PM
  3. TPS? PROBLEM.. HELP PLEASE
    By sarty4 in forum Problems and Maintenance
    Last Post: 05-25-07, 09:26 PM
  4. GMR now offers Performance Windshield Wipers **Pics**
    By Co Pilot in forum SRT4mation.com Site Discussion
    Last Post: 01-19-06, 01:37 PM
  5. new windshield.....where in SJ can i get one??
    By Ricer in forum New Jersey
    Last Post: 11-02-05, 11:00 PM
