Results 1 to 9 of 9
Thread: STICKY GEARS?
    Extreme Poster sarty4's Avatar
    Long Island, NY
    STICKY GEARS?
    Hi all,
    I'm having this little issue.. ever since midday today my gears have been harder to get into and out of. This holds true for all 5 and reverse. I know these trannys give us a hard time, but I never heard of any problems getting it out of gear. It's not that bad, but I definitely felt a difference and it the problem came up out of the blue.. didn't get progressively worse or anything like that. Replaced the tranny fluid less than 10k ago.
    Any ideas? Cooler weather? Clutch getting older (67k stock)?
    BottomOfNewYork TopOfNewYork's Avatar
    Nueva York
    did it happen when you hit high rpm's?
    if so them change that clutch
    Long Island, NY
    nope, i don't even think it happened while driving. went to school everything was good. left school car was acting weird.
    Long Island, NY
    bump..
    Major Poster srtjay's Avatar
    NY
    when was the last time you changed out the tranny fluid?
    Long Island, NY
    Quote Originally Posted by srtjay View Post
    less than 10k:readclose
    Sr. Member Bungles's Avatar
    Something easy to look at are your shifter bushings. Make sure they're lubed up especially the ones sitting on the tranny. I would also grease the shifter inside the car. I had similar issues and greased up the shifter and things got better. These are just some of the things to check easily.
    Then of course there's the clutch and the tranny itself. We all know Jay is the master of transmissions so it may be beneficial to have him look at it.
    Good luck and hopefully it's something small.
    Long Island, NY
    sounds good, thanks man
    Might be the Throw Out Bearing Fork. When it wears too much, you will have problems disengaging gears. Nemo from Rage-Tek has some good info here:
    http://www.srtforums.com/forums/showthread.php?t=378048
    Nemo has a replacement for the mechanical TOB Fork. If this is your problem, then you might look at the Rage-Tek Hydraulic Clutch Release Bearing.
    http://www.rage-tek.com/product.php?productid=16196
    Hope this helps.
  1. AEM GEARS?
    By DAROOKE in forum Performance Modifications
    Last Post: 04-04-07, 11:48 PM
  2. Srt4mation personal info sticky
    By mo'sSRT4 in forum California
    Last Post: 07-07-06, 08:40 PM
  3. In car Action .........with Sticky Pod
    By Vade46 in forum SRT-4 Videos
    Last Post: 03-24-06, 10:23 AM
  4. sticky tires
    By 05ocsrt-4 in forum Performance Modifications
    Last Post: 03-04-06, 02:15 AM
