Results 1 to 18 of 18
Thread: ok got codes, what does it mean?
    Newbie Layz's Avatar
    May 2006
    NJ
    i got three:
    0068 said it was manifold pressure, throtle position correlation.
    0339 crankshaft intermit
    0633 Skim key not programed in PCM
    This all happened with a few days, any ideas? I have looked at wires and they look good to me.
    Jr. Member Nolimits's Avatar
    Near the Lab of Dr. Weird
    0633 skim key, means you have stage 1, 2, or 3 and need to get it flashed with the skim key at your dealership
    Post Master scarface2jz's Avatar
    Jul 2006
    long island, NY
    you also have a boost leak, or you overboosting... and the crank position sensor is common, need a new sensor
    May 2006
    NJ
    The sim key can just go? glad i kept my original PCM. Guess i'm headed to the dealer this weekend :)
    Extreme Poster sarty4's Avatar
    Long Island, NY
    curious, when was the last time you changed your plugs? and whats the gap?
    May 2006
    NJ
    Last year, also did the wires with the MSD ones, think they are 8.5. The gap i believe was .23.
    Jr. Member SuperMario's Avatar
    Central Jersey
    Quote Originally Posted by Layz View Post
    .23 is too tight...open them up to .35
    May 2006
    NJ
    The only thing chanig the plugs did was make them look pretty. Still have major stumble when i go about 13% or so on the gas.
    4m Milestone Whore Award 20k oo3menace's Avatar
    New Jerz
    Stock coil pack?
    May 2006
    NJ
    Yes, i was thinking about that as well. It's just wierd, it is ok just seems like it goes fine i get into a certain band then it has issues. Once i get out it is fine
    New Jerz
    Have you boost leak tested the car? Possible injector leak/manifold gasket? What other mods do you have? Stock fuel setup? Do you have a wideband? Do you hear a whining from the fuel pump/tank area? Are you using anything to tune with?
    Member boostedneon04's Avatar
    Long Island
    Quote Originally Posted by oo3menace View Post
    May 2006
    NJ
    Last of the PSI-FI cars, It is their entire setup. Turbo 50 trim, manifold, power-paq, and traction bars. No boost leak was done on the car as of yet. I was thinking about taking out my stage 1 pcm and putting back my original, just to see if it is the pcm. I still have to check the TPS wires, so hopefully i can do that tonight.
    Long Island, NY
    Yeah .028 is tiiight IMO
    New Jerz
    malfunctioning ppq? Do you know how to tune/use the ppq software? Does your ppq have the vac line attached to it? Is it ripped/damaged? What type of fuel upgrade did the psi-fi kit include?
    crank sensor or cam sensor
    i got three:
    im 100% sure if you change both your problem will be solved
    May 2006
    NJ
    Sort of, i took a look at the map that is in there. Just a bunch of numbers to me to be honest. Not sure if - means more fuel or not. Looked at them and it has - increasing as RPM gets higher. I would think that is wrong but the car did work fine before. I'll replace the sensors can't hurt.
    May 2006
    NJ
    Ok i give where is this crank sensor? and if i was to test the TPS what are the volt readings i'm looking for?
  1. Codes
    By mleeyow in forum Problems and Maintenance
    Last Post: 11-01-07, 08:10 PM
  2. 2 codes?!?!?!?
    By Munky in forum Problems and Maintenance
    Last Post: 10-16-07, 03:29 PM
  3. some codes
    By 05beastsrt4 in forum Problems and Maintenance
    Last Post: 05-13-07, 10:15 PM
  4. no cat d/p and no codes?
    By NjDodge in forum Performance Modifications
    Last Post: 11-27-06, 06:22 AM
  5. codes please help
    By raven3054@aol.com in forum Problems and Maintenance
    Last Post: 03-30-06, 08:52 PM
