panic.
i was just going around my car makin sure all vac line were all on i was lookin at the hose from my bov and it didnt look all the way on so i try puttin my hand down to the bov to get the line on then when i stated my car the cel was on so i hook my scanner up to it n i got p0108 map sensor voltage to high and i went and i was movin the wires on the map sensor then another code came up sayin voltage to low n thnen it started sounding like i had cams.what should i do
Has there ever been a mapclamp wired into your map sensor?Any electrical tape on the wires?Make sure there aren't any broken (cut) wires on your map sensor.Make sure if there is a bare wire showing that its taped well or shrinkwrapped.If there is a frayed wire you'll have too rewire and solder it?Might need a new map sensor but I never heard of them go bad before?The line going too the BOV was loose or completely off?Do you have a fuel computer?Piggyback?Where are you from?I would try too reset the computer my taking the negative battery cable off for like 15 minutes and take it too someone too fix it.
i hit some wires on my tps and i think something might of happen cause i heard the wires on the tps go bad and u have to replace the whole thing and thats y my car keeps stalling and it sounds like cams
