Results 1 to 12 of 12
Thread: Can someone help me redo my lines?
    Jr. Poster
    Oct 2006
    My bov wont blow off cuz i got stage 2 and my lines arent done right... Can some1 help me redo my lines? im in edison nj
    Major Poster slvrsrt4nj's Avatar
    Aug 2006
    North Jersey
    how is the bov connect? is it a bov on the ic piping or the stock or mopar bov on the turbo?
    Jr. Member fourbanger's Avatar
    Pa
    the pink line coming from the solinoid pack should connect to the bottom of the turbo. The blue line should be coming from the source boost. Green should connect behind the turbo.
    The blue and the pink not being connected would make a mopar bov not work. Im assuming thats what you have. Good luck. The vacuum chart is on the bottom right hand side of the hood when its open. That should help you out some.
    Jr. Poster
    Oct 2006
    Its a HKS SSQV and its connected on the bottom right hand side of my car...... I guess ill try and fix it my self =/
    4m Milestone Whore Award 20k oo3menace's Avatar
    New Jerz
    The vac line running to it should T off the throttlebody, not use the one on the solenoid for the surge valve, and the surge valve should be blocked off.
    Jr. Poster
    Oct 2006
    Menace, come help me fix it... Pleeeeeeeeease.. I live walking disance from ur job
    New Jerz
    Have you checked for boost leaks? Are you sure it's just your vac lines? Everything on your solenoids should be the same as stock excet for the surge valve solenoid, which shouldn't have lines attached to it.
    Jr. Poster
    Oct 2006
    Quote Originally Posted by oo3menace View Post
    I dont know anything, i dont know what a line or solenoid looks like....
    Major Poster Frodo's Avatar
    i met you at rita's. his bov looks like it is hooked up correctly from what i could see in the dark. from the mods you told me you had and the dyno numbers you told me, it sounds like you have a MASSIVE leak somewhere
    Jr. Poster
    Oct 2006
    Hey frodo whats up, Yea its me from ritas.... I donno man i lost to a stock stage 2 car and my mods r listed below..... My bov just doent blow odd but i get tat intake flutter sound...... Frodo can you take a look at my car or something? Ill throw u some $
    Ripp Mods 16 G turbo
    Agp wastegate
    650cc injectors
    Boomba fuel rail
    Stage 2 PCM w/ map and tip sensors
    Apex I Safc 2
    Aem ugo Wideband
    Needswings Downpipe w/ E cut out
    2.5 inch magnaflow catback
    Quick whips DFirect fit FMIC
    AEM Short Ram intake
    HKS Hssqv BOV
    Ed hard pipes
    Ripp Catch can
    Motor mounts
    Ironman stage 2 competition clutch
    Quote Originally Posted by Laced View Post
    Agp wastegate
    650cc injectors
    Boomba fuel rail
    Apex I Safc 2
    Aem ugo Wideband
    HKS Hssqv BOV
    Ed hard pipes
    Ripp Catch can
    Motor mounts
    maybe next week. i have a weird work schedule so i have to see what days i have off. u definitly should have not lost to that kid
    Jr. Poster
    Oct 2006
    Quote Originally Posted by Frodo View Post
    Yea I know, And he pulled Haaaaaaard on me
  1. ? on vacume lines
    By LilSrt161 in forum Problems and Maintenance
    Last Post: 05-15-07, 10:15 PM
  2. Vacuum Lines
    By Breakin Newz in forum Performance Modifications
    Last Post: 02-20-07, 11:50 PM
  3. vac lines
    By 05beastsrt4 in forum Performance Modifications
    Last Post: 01-04-07, 09:39 AM
  4. vac lines
    By Scapegoat in forum Performance Modifications
    Last Post: 04-16-06, 01:28 PM
  5. New SS brake lines
    By htheduck in forum Performance Modifications
    Last Post: 10-10-05, 10:54 AM
