Is this a serious question? We have a "How-To" and SEARCH on these forums. Help yourself to either one of them, lot's of info on this subject.
is there anything i can do it get rid of the vac lines and have them hooked to something else. or anything
pull all the vac lines out and replace them with pink string...:woot:
i'll try to be a lil more helpful than Hozay. however i would suggest going through the How-To's and using the Search feature to get more detailed information. basically, depending on ur set-up, u can remove the vac lines altogether. for example, get stage 1, wga, and external bov. with an external bov, the pink line becomes irrelevant and once u take control of the boost away from the PCM, the rest of the vac lines become almost pointless.
however, if ur running stock or any of the staged set-ups then don't touch the vac lines.
there's more that can be said and some others may chime in with more detailed and accurate info or they may just tell u to use the search feature. either way, i got to kill 5 minutes at work so i'm happy!
